跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153 个问题 查看全部
Why won't my transmission go into drive
2005 Nissan Altima Transmission won't go too drive just 1,2, n 3rd. When you put shifter into drive it shows up as 3rd on dash instead of D. Runs and shifts through first 3 gears fine just won't even try too go into Drive
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If you have the regular automatic the slot where D is has more to it. If the gear position characters say 3 D with 2 and 1 below the 3, the left side of the slot is for 3rd, while the right side of the same slot is actually D. It's quite easy to drop it into 3 straight from Park and/or Reverse, especially if you're in a hurry. Just push the shift lever directly towards the passenger door, you'll feel it grab another gear, assuming everything else is good. I hope this is all the problem is, and if it is don't feel bad. My wife drove our 02 in 3rd for the first two months we had it! :-)
这个答案有帮助吗?
得分 0
1条评论:
I have tried everything and still have this problem
完成的
添加一条评论
添加你的答案
Jeremy Farthing 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 10
总计 4,496
