跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
iPhone 5 home button doesn't work after dock connector replacement
I had charging issues with my iPhone 5, so I ordered a new lightning port connector. I installed it and the charge issues are no more. Now the home button doesn't work. I tried shorting the two gold prongs while the phone was open and it did not trigger the home button.
If I connect the old lightning connector cable and try shorting the gold prongs, the home button works fine.
This could only mean that the lightning connector I ordered is faulty? I installed it correctly with washers and such, and the metal flex cable that wraps around the headphone jack lies on top just like in the guide photos.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi was my answer helpful? do you need any more help?
完成的
Hi!
Replacing the dock again helped. Thank you!
完成的
添加一条评论
3个答案
已选择的解决方案
Aftermarket charging port have a very hight rate of defect.
Make sure you test follow
-Charging
-Headphone
-Home button
-Speaker
-Mic
sometimes only 1 out of every 5 charging ports you purchase is fully working.
这个答案有帮助吗?
得分 1
添加一条评论
Definitely a faulty new connector. If you short the prongs and get nothing, there isn't much else to explain that. I will say that while this may or may not be true with you, I have "fixed" many lightning cable connectors bu simply cleaning out the port itself. Pocket lent and other dust like to accumulate and pack down inside, preventing the cable from clicking in all the way. you can use a paper clip or if you have some pointy tweezers, and just scrape it out (Careful just to scrape the "bottom" of the hole and not the sides). But if that doesn't work definitely see if you can get the new port replaced from wherever you ordered it from.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for the quick answers. Headphone jack, microphone, speaker and charging works. It's only the home button that doesn't work. The reason to why I replaced the old connector was because the phone indicated a drained out battery with a red symbol, and didn't charge when usb cable was plugged in. I completely cleaned out the connector from lint (there was some) but the problem still existed. I tried reseting phone, and suddenly it could charge fully once. But after one charge, and drain, the problem was back. It occured after dropping the phone, and denting the lower left corner. I will have to get a new port then.
完成的
添加一条评论
I have the same problem and what I figured out was that there was a missing ribbon on the new charging port unit, one that popped up over on the top of the unit.
There is a work around, by changing the accessibility features and turning on touch assist.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,807
