跳转到主内容
苹果发布了MacBook Pro 15英寸一体化机,采用新的铝质表壳,由单个铝块加工而成。
2989 个问题 查看全部
Why is my wifi icon and hardware missing?
I have a macbook pro 5,3 15 inch unibody mid 2009 on Mavericks and the wifi is not working ...The icon does not show ,I tried to create a new network in system preferences and the wifi option wasn't available, I click network diagnostics and the wifi option was grey. I believe it's not hardware because in the beginning wifi was good when my hard drive was wiped that's when it occured
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 2
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
Hey! You must make sure drivers for wifi card is installed on your macbook fully, becosse problem after HDD replacing...
这个答案有帮助吗?
按维修分数 0
评论:
Where can you find the drivers to install ?
@emailgregnow - Sadly, this is not the correct answer. The drivers are part of the OS-X so simple act of installing the OS you get what you need. It sounds like you have a hardware problem like MichaelJrRekson has. There is a few things here you can try to fix this. I recommend you create your own question with all of the details so we can work it out with you.
添加一条评论
添加你的答案
MichaelJrRekson 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 12
总计 1,497
