跳转到主内容
The VAIO RZ14G is another example of Sony's innovation and ingenuity at it's finest.
4 个问题 查看全部
How control fan speed
I have laptop Sony vio .i bought 3 months was no noisy .but now fan speed work very hard
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
iPhone 电池维修工具包
只要 $29.99
Buy Now
iPhone 电池维修工具包
只要 $29.99
Buy Now
2个回答
最有帮助的答案
Noisy fans are usually caused by dust sticking to the fan blades.If you have access to compressed air try blowing air backward through the fan. Be careful not to use too much pressure. Compressed air in a can works well. If you know what your doing opening the computer up and physically dusting the fan is another option.If not blowing out the fan by air flow running both in the exhaust and out the exhaust.a few times can get a lot of dust out.If the fan has run out of balance long enough it can actually damage the bearing and then the fan will need to be replaced. Hope this helps Good luck
这个答案有帮助吗?
按维修分数 1
添加一条评论
aishakhalifa, if you bought in new, get it covered through Sony 's warranty. Otherwise use this teardown and clean/replace the fan
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
aishakhalifa 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 15
总计 1,727
