跳转到主内容
The first FWD car to be exported to North America by Volvo
7 个问题 查看全部
Diagnostic unit on 850 GLT
Where is the diagnostic unit on a Volvo 850 GLT 1997? It's not in the same place as my 850 SE. Front right by the washer filler.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
Hi, I think this the answer you are looking for. Ralph
http://www.volvospeed.com/CheckEngine.ph...
Second location
http://www.matthewsvolvosite.com/forums/...
这个答案有帮助吗?
得分 3
添加一条评论
The ODBII connector is under the coin tray in front of the shifter
这个答案有帮助吗?
得分 0
添加一条评论
Your newer 850 96&97 will need a obd2 scan tool reader to get the check engine codes. The plug in port is below the ash tray under the coin holder. Your older volvo is an obd1 and codes can be retrieved by a blinking led light.
I think auto zone stores. will check the codes at no charge.
Bob
这个答案有帮助吗?
得分 0
添加一条评论
I just found out that on our standard 95 850 GLT wagon the plug in ... is behind the passenger head lamp but they take a special type of reader not just any and under the hood toward the wind shield a sticker will tell you if its a I or II .... so now im off to find one of these special readers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Sheppard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 11,819
