跳转到主内容
Released July 24, 2014, Amazon's Fire Phone is Amazon's first smartphone, designed to compete with iOS, Android, and Windows Phone devices.
45 个问题 查看全部
SIM card Tray lost. What can I do?
My friend lost the Sim tray and now cannot put her micro Sim in her 'phone. I tried opening the 'phone to see if there was a way to put a SIM card adaptor in it with the SIM card in it. No luck. Can you please tell me where I can buy a new SIM card tray?
Thank you :)
TJ
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
评论:
I lost the tray and i just put the Sim card in to my phone and its saying that “sim card is not for voice what do i do?
text me on instagram @ericmurillo115
完成的
Please make sure the SIM card has bee balanced in the phone so that all of the contacts line up. I lost my SIM card tray and had no problem lining the card up. Just remember not to drop the phone or else you will have to realign the card.
完成的
添加一条评论
9个回答
已选择的解决方案
You can find a Amazon Fire sim card tray here.
http://www.ebay.com/itm/OEM-AT-T-AMAZON-...
这个答案有帮助吗?
得分 2
评论:
Thank you so much! Awesome!
完成的
pls recvest u sim tray fire phon model SD4930UR
完成的
I did the same but with a Blu phone where can I get a sim card holder for that
完成的
I broke my tecno camon 15Air sim card tray.Can i find another one to replace it??
完成的
添加一条评论
最有帮助的答案
US$ 29.95 is a scandal! I used an old iphone tray and sanded the edges with a file tool. Not so elegant but works fine.
这个答案有帮助吗?
得分 5
评论:
what version iphone did you get the tray from?
完成的
Did u use an iPhone 4 tray?
完成的
添加一条评论
You're looking at about $25-30 for the Fires' unique, korresponding SIM tray; UNLESS, your kraftsmanship possesses the necessary experience required to konvert the dimensions of some other, non-korresponding SIM tray, konscientiously into the replikated magnitudes of the original SIM tray, precisely.
这个答案有帮助吗?
得分 1
添加一条评论
I recently lost mi Chinese goophone Samsung S6 sim tray holder where can i buy a replacement..thank you
这个答案有帮助吗?
得分 0
添加一条评论
My Question is a littel bit different
The sim card reader of my amazon fire phone is damage so i want a new one please tell me from where i can get it.
这个答案有帮助吗?
得分 0
添加一条评论
I was feeling frisky and bought an iphone 4 sim tray. Its WRONG! Its upsidedown. Ohh well it was only$1.65 wasted.
这个答案有帮助吗?
得分 0
添加一条评论
my sim tray of Vivo v7+ cracked and broken, i tried to consult various vendors ,but nothing Works out .Kindly suggest is there any Way to get fixed
这个答案有帮助吗?
得分 0
添加一条评论
I lost my sim tray and I just put there sim card and now I can’t take back?????
这个答案有帮助吗?
得分 0
评论:
You can use two paper clips bent out, or needles or something thin to pry out the sim card with enough patience and maneuvering of the card. There is more information on youtube on how to do it
完成的
I also lost my Sim card and it's tray a d am having a real hard time finding one I don't have a job right now so what should I do if I can't buy one
完成的
添加一条评论
Probably the next most common thing, if you happen to work in an office. Not the fat plastic-coated paperclips, but pretty much any small metal paper clip will get your SIM tray ejected. And when you're done, you can use it to attach various bits of paper together. regards WhatsApp Sniffer App
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Telea 将永远感激不已
浏览统计数据:
过去的24小时: 15
过去的7天: 74
过去的30天: 428
总计 47,057
