跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
467 个问题 查看全部
Replaced DC-In Board but battery is still not Charging?
Hey guys,
Replaced my DC-In Board but im still getting NOT CHARGING on my system profiler. So does this mean I have to replace my battery? This question was in part with my other one that asked about the mojito spilling on the top left corner of the laptop.
So i ordered the DC In Board and replaced it. But still not charging. So is it safe to say that I need to buy a new battery?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个回答
已选择的解决方案
This could be anywhere from the battery, or the cable connecting the battery to the logic board. Like remacberlin said you should first use coconut battery and see what it says. System profiler could also tell you how much amperage is left in the battery, a healthy batter is anywhere from 4200-5200.
Hope you figure it out.
这个答案有帮助吗?
得分 0
评论:
okay. But I downloaded coconut battery and everytime i open it, it keeps crashing. Why is that?
完成的
I couldn't tell you exactly why this is happening. You could just look at your system profiler to see the health of your battery.
完成的
添加一条评论
最有帮助的答案
Have you tried coconut battery to check out the health of it?
这个答案有帮助吗?
得分 1
评论:
I downloaded coconut battery but it keeps crashing. It says unexpected error. It keeps popping up when I open it.
完成的
添加一条评论
I've also replaced DC-in and battery is still not charging... Coconut battery works fine and I also tried to replace the battery but no luck. Even though it happened because of liquid damage, there is no signs of corrosion nor burning on the logic board. Any idea how to fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fred 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,186
