跳转到主内容
加入维修社区 - 创建账户
BLU Studio 5.5 于 2013 年 10 月 1 日发布,是一款无锁 Android 智能手机,拥有 D600(单卡)和 D610(双卡)两种机型。
My phone screen is white
I took out the battery let it stay for a while, but screen is still white. What can I do? Help please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
my itel it1503 phone shows white on the screen when i changed the screen
完成的
Can we repalce the lcd and touch of Huawei y560 U02 with y541 U02?
完成的
添加一条评论
2个答案
最有帮助的答案
I seen your other post that said this happened after the phone had been dropped. A white screen usually means that the LCD in the display assembly has either been damaged or its connection to the logic board may have come loose. The LCD is the part of the display that is responsible for displaying the image on the screen. So you may want to disassemble the phone enough to be able to check its connections to the logic board. If the LCD connection is properly seated to the logic board then the LCD was definitely damaged during the drop and will need to be replaced. If there are any cracks in the screen I would suggest replacing the whole display assembly. Hope this information is useful for you.
这个答案有帮助吗?
得分 7
1条评论:
When Im using my phone it just shuts the display and using only backlight. But everything is okay just the display doesn't show anything. It still functions but no display. Can you help me?
完成的
添加一条评论
3 things you need to check. First of all chech the LCD cable to see if it's lose. then disconnect the front camera and turn it on. If it turns on it's proximity sensor if not test the battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michelle Mullo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 28
总计 19,631
