跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
问题已关闭
Why does my iPad randomly get brighter?
My iPad 2 EMC2560 has lost much of it's brightness. It will randomly get bright (brightness level it should be), but it never lasts very long and I can make no connection between the events that lead to said brightness.? Any help/ advice appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you ever taken your iPad apart? If so, it may be a backlight issue with the LCD, in which case you need a new one.
It also might be a setting, on Apple devices you can make the iPad set the brightness automatically- make sure that's turned off.
这个答案有帮助吗?
得分 0
添加一条评论
Is your iPad in a case?, the case could be blocking the backlight sensor ( just above front camera) causing your iPad to think it is dark and should lower the backlight. Try remov Not the case of turning off auto brightness as You Just suggested
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 113
