跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1623 个问题 查看全部
What can I do to improve the performance?
Hi,
can anyone tell me how to improve the performance of my MBP? I'm a student of interior design so i have to do a lot of 3D max, sketchup and those photoshop thingy but my MBP is not working smoothly and it will stuck sometimes. Is there anything i can do to fix it or to improve the performance of it?Please advise thanks :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
How much RAM is currently in your Machine? Check by going to the Apple Menu in the upper left corner, selecting about this Mac, and looking at the spot that says Memory.
完成的
This laptop was not designed for that kind of workload. You're better of custom building a tower.
完成的
4GB installed
完成的
添加一条评论
1个答案
最有帮助的答案
There are easy do-it-yourself upgrades that will give you a speed boost.
  • Install more RAM. A Mid 2012 13" MBP can use up to 16GB total. You generally get better performance if you install RAM in matched pairs (2x4GB, 2x8GB).
  • Install faster storage. In order of increasing speed, your options for replacing your stock 5400 RPM hard drive are:
    • 7200 RPM hard drive (examples: Seagate Momentus XT, WDC Black)
    • SSHD (platter HD with large solid-state cache)
    • SSD
    • the price-per-GB of these drives increases with the speed; traditional hard drives (250GB-750GB in 7200 RPM) are cheapest, hybrid drives (128GB-1.5TB) are more expensive, solid-state drives (128GB-1TB) are most expensive.
The installation guides are available from iFixit, as are several of the replacement parts; the parts are also available from a variety of online retailers.
Graphics applications benefit from more RAM, since they allow you to open more/larger images without swapping out to comparatively slower virtual memory. But Photoshop in particular benefits from faster storage, since it uses its own virtual memory scheme separate from the one used by OS X. If the disk where the virtual memory space lives is much faster (as with an SSHD or SSD), then you take less of a speed hit when the program starts moving data back and forth between RAM and disk.
PC3L-12800 4 GB RAM Chip图片
产品
$29.99
MacBook Pro 13" Unibody Mid 2012 RAM 内存条图片
指南
MacBook Pro 13" Unibody 中期 2012 RAM内存条更换。
难度:
简单
15 - 30 minutes
MacBook Pro 13" Unibody Mid 2012 硬盘图片
指南
2012年中期13寸 MacBook Pro 一体化机更换硬盘
难度:
中等
30 - 45 minutes
这个答案有帮助吗?
得分 5
1条评论:
Very well done answer!
完成的
添加一条评论
添加你的答案
Jayson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,528
