跳转到主内容
The third generation of Galaxy Tab including a 7.0, 8.0 and 10.1 inch display versions, as well as the Galaxy Tab 3 Lite 7.0. Released in July 2013.
443 个问题 查看全部
Why is my screen flashing (samsung galaxy tab3)
my samsung galxay tab 3 has been working fine all day now all of a sudden its turned of but flashing (samsung galaxy tab 3) or if put on charge will just flash the empty battery symbol whats wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
were will i find the battery in the tablet
完成的
添加一条评论
3个答案
已选择的解决方案
Have you tried taking the battery out.then put back in and put on charge for 1 hour. Don't try to boot until it has a good charge. I think it's a super flat battery...hence it can't boot.
这个答案有帮助吗?
得分 1
2条评论:
Don't do that as you device having non removable battery. if you don't have good knowledge about high capacity Li battery handling, be careful!
完成的
Actually it is removeable. Difficult but doable depending on which tab he has. My mistake I misread and thought it was a s3...however the symptoms are the same..super flat battery.
完成的
添加一条评论
Leave the tab on charge at least 3 Hrs and turn on and check whether same fault can be observed.
这个答案有帮助吗?
得分 0
添加一条评论
probably there is virus within .
这个答案有帮助吗?
得分 0
1条评论:
@fallenangel0901 how do you fix that? Why would a virus cause this?
完成的
添加一条评论
添加你的答案
kingsthorpejetsmad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 15,259
