跳转到主内容
PlayStation 3 Slim是Sony Computer Entertainment生产的PS3视频游戏机的第二版。 它于2009年9月1日发布。
465 个问题 查看全部
Why won't my PS3 stay on
My PS3 won't stay on. I was playing assassins creed 2 & it froze. I turned it off & turned it on again but now it won't boot up properly. I tried the reset by holding it down for 10 seconds but instead of the beeps I'm supposed to get, it just powers off & if I leave it on without holding down power button, it turns off after about 30 seconds
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
This type of behavior is usually caused (at least initially) by heat. After a while, the heat compound on the CPU breaks down and is not able to transfer the heat from the CPU to the heatsink properly. This leads ultimately to overheating. Once this happens, all bets are off. Most likely, the CPU overheats right away which is why the system shuts down. Start by replacing the heatsink compound and to run the system again.
Let us know how you make out...
Dan
这个答案有帮助吗?
得分 1
添加一条评论
Same problem here. Did y'all find a solution?
这个答案有帮助吗?
得分 0
添加一条评论
I believe that it may be a power-supply problem, which causes it to lose power after a few seconds when the HDD activates.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stephenmurphy28 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 651
