跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
330 个问题 查看全部
iMac 27 mid 2012 Fan blowing at full speed
Ok, the stand of my Imac broke, so I opened up the Imac myself and replaced it with a new stand. After closing the Imac together, the fan blows at full speed. I have not changed any parts.
I tried to find a solution to the problem. Have done SMC reset and PRAM reset a zillion times, this does not solve the issue.
I have opened up the computer again and tried to see if there was any cables to the fan that wasn't set right, also checked cables to the hard drive.
Any solution or idea? Tried to find something about this, but most solutions seems to cover earlier Imac versions.
Best Regards
Andreas
Update
Hi Dan,
Thanks for your response!
Here comes the screenshot!
Best Regards
Andreas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Lets see if we can identify what sensor is giving you trouble by running this app: Temperature Gauge Pro. Post a screen shot for us to see.
这个答案有帮助吗?
得分 2
9条评论:
Added screenshot above! thanks!
完成的
Did you replace your HD? It appears the drives sensor is not working. This model of iMac requires a special cable adapter when using either a HD or SSD which is not an Apple drive or one that supports the way Apple accesses the drives internal thermal sensor.
完成的
No haven't changed anything inside but the broken henge/stand. I did actually open it again to see if the cables were loose or not set right, but everything seems to be correct, is it a cable that easily break?
完成的
Hi Dan,
Here comes a screenshot, it says though that "These sensors appear to be not working properly: Unknown"
Any idea?
Link to screenshot:
http://screenshot.net/3rnpwfw
Thanks!
Andreas
完成的
What drive do you have in your system? A HD or a SSD, or a Fusion Drive.
完成的
显示更多的4条评论
添加一条评论
Inline Digital Thermal sensor DIY Kit from OWC will fix your fan & also the processor load
https://www.amazon.com/gp/product/B00J42...
Installed many of those on all new 27 retina display, working great
这个答案有帮助吗?
得分 0
1条评论:
That's for use when you change the hard drive. The OP stated he had not done that.
完成的
添加一条评论
添加你的答案
andreaslindell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 1,312
