跳转到主内容
A 14.1 MP camera capable of photo and video released in February 2011. Now discontinued.
17 个问题 查看全部
How to Fix no Power
How to Fix no Power...i dont know how to fix this...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
It looks like I have some corrosion in one of the battery chambers of my camera, is there and way of sorting this and repairing??
完成的
添加一条评论
2个答案
Check the wires and contact of the batteries. If all are good. Check polarity of batteries. If all is good. A tiny line of the circuit board is burnt because you put the batteries in a wrong way And there is no fuse.
这个答案有帮助吗?
得分 0
1条评论:
If there is burnt bit in the circuit board and no fuse what can I do to fix this problem?
完成的
添加一条评论
To fix the burn in the circuit board you have to have a soldering gun, flux paste, tin- lead and good soldering skills. To repair , first you have to find the area that has the open circuit, then remove the green material that protects the cooper for corrosion. Put a bit of flux paste on the expossed part of the circuit that we previously peel. Then solder the area putting a bit of tin-lead. Find a piece of wire (small caliber..18-24 gauge)to make a bridge in the 2 areas.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cilmarbbacus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 1,662
