跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone taken down to 100 feet for 1 hour. Salvageable?
So I may of accidentally brought my iPhone scuba diving with me.
:-O
I was under the sea for approximately 60 minutes, with a max depth of 100 feet for a good portion of that.
Any chance the extended full submersion, short circuiting and pressure (4 atmospheres, approximately 60 PSi) didn't completely fry the phone and render it 100% useless?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Diver Dave, I would definitely give it a try. Do not try to sync, charge or to turn your phone on. I suggest you totally disassemble your phone by using [iPhone 5|these guides. Remove the EMI shields as well. Then clean everything with a high grade (90%+) isopropyl alcohol. Carefully inspect your logic board for any missing, charred or otherwise damaged components. Once done, replace the battery, the lightning connector and most likely your display assembly as well. Then re-evaluate. Let us know how it is going and post some images to see what it all looks like.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Diver Dave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
