跳转到主内容
How do I fix my Beach Cruiser's kickstand?
My beach cruiser has a loose kickstand and I'm not sure what tool to use to tighten it. It seems like a quick fix. What tool(s) should I use?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
已选择的解决方案
Yes, this should be a quick fix. It comes down to the type of kickstand you have and the type of bolt it uses to attach to your bike.
Most clamp-on style kickstands look something like this. Follow this procedure:
  1. Sandwich your bicycle's chainstays between the top plate and the bottom plate (which is attached to the kickstand).
  2. Feed the bolt down through the holes in the top plate and the bottom plate. The bolt is typically a 14 mm hex head type.
  3. Tighten the bolt using a 14 mm socket wrench (if you don't have one, an adjustable wrench should work just fine).
  4. Be careful not to overtighten; you don't want to damage your bike frame by crushing the chainstays.
Some bicycles have a built-in kickstand plate. (Look for a flat piece of metal welded between the chainstays down near the bottom bracket shell, right behind where the cranks attach to your bicycle frame). Bikes with a built-in kickstand plate don't need the clamp-style kickstand shown above. Instead, you will need a kickstand that looks something like this.
These kickstands typically attach using a shorter allen head bolt. So you'll need an allen wrench (usually 8 mm, but could be 10 mm or even 14 mm) to attach this style kickstand to your bike's existing kickstand plate.
Hope this helps!
Smart Wrench张图片
产品
Smart Wrench
$24.99
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
Jizelle Boctor 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 31
过去的30天: 174
总计 6,231
