iPhone 6 gets really hot after screen replacement
Hello guys!! I fixed it an iPhone 6 for a customer on Saturday everything was ok but I didn't test the phone. The customer came on Monday and he says that the ear speaker won't work.
I open the phone everything is connected properly on the front camera ear speaker but the phone gets really hot and the front camera and ear speaker doesn't work. You guys have any idea?
Best.
3条评论
same case with me. after the replacement of screen, my iphone 5s is really easy to get hot, and now and then it have no response when i touch the screen.
由 loucy cusin 完成的
I had the same camera/proximity sensor overheating problem. I miraculously found a fix. There is a black, thin, foam-ish looking sticker on the opposite side of the connector part of the cable. There are one of these stickers on most of the ribbon cable connectors throughout the phone. They are there to prevent the metal on the backside of the connectors from touching other metal. Well my original sticker got pushed/moved off center exposing a decent amount of metal. The exposed metal from the connector was directly touching the cover plate that screws over top of the connector. I took one of those little black stickers off of a random cable connector from my old screen and placed it onto the backside (the side facing up after snapping in place) of my cam/prox connector where there was zero metal showing. I Wham, bam thank you m’am, worked like a charm.
由 Kyle 完成的
Check the ribbon, it shoud be damaged or teared
由 Hasanthini Charuka herath 完成的
