跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
202 个问题 查看全部
Bad Wifi reception after LCD replacement
I bought a HTC One M8 with cracked screen. Today i replaced the LCD and i notice very bad wifi reception. Did i damage something or forgot something?
I don't know where the wifi connector is located, and can't seem to find the answer on the internet.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I have the same problem now. If you know what to do, please write it down
完成的
添加一条评论
2个答案
hi
The problem is that you simply forgot to install the reinforced tape signal for Wi - Fi.
see photo ===>>
WiFi fix
https://s22.postimg.cc/islbn1s69/wifi_fi...
Thank you
这个答案有帮助吗?
得分 0
1条评论:
Also this can be caused by damaged antenna connector or cable in case anyone wanted to know, but most of the time like you said forgot to put back the Wifi antenna cable.
完成的
添加一条评论
I need help. I changed display and i have poor Wifi signal. I connected all that needs to be connected. I think that i damaged cablr, but i don't now which one is for wifi. I will probably buy a full new set. Please if someone know which cable is for what text me. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gregory 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 752
