完整的更换指南,从初代iPhone、iPhone 3G、iPhone 3GS、iPhone 4、iPhone 4s、iPhone 5、iPhone 5c,iPhone 5S,iPhone 6、iPhone 6 Plus,iPhone 6S,iPhone 6S plus,iPhone 7,iPhone 7 plus,iPhone 8, iPhone 8 Plus, 和 iPhone X.
31401 个问题 查看全部
Soldering U2 (what tools needed?)
Hello everyone,
I would like to start micro soldering, i have phone compagny but sometime we broke some chip during repair.
What is all tool needed for remove U2 chip and replace with new one ( i already have the new U2)
Can someone explain me how to desoldering and how to soldering back, which method is the best ?
Thanks
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
Hey,
You'll need to start off by getting a good soldering iron, something along the lines of a Hakko, then you will need decent flux, and decent solder at different widths, for smaller stuff go with the thinner soldering wire, try and make sure it's multicore solder as that also contains flux in the solder and helps a lot. A good reflow station will be needed for sure. You will definitely need a decent microscope to, you can't do it by eye, as the chips are so tiny! If you do plan on soldering a lot, you'll more than likely need a fume extractor, as the fumes from soldering are bad for health.
Hope this has helped. :)
这个答案有帮助吗?
按维修分数 2
添加一条评论
Tools only:
Hotairstation/Reworkstation
Soldering Iron
Solder
Flux
fine quality tweezers (also important)
Changing the u2 chip is one of the easier IC's to change but still not the place to learn micro soldering.
Practise and get to know your tools on dead boards until you know how to remove parts without destroying the whole board.
这个答案有帮助吗?
按维修分数 0
添加一条评论
PPD120E or good soldering iron
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Phonetech93 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 24
总计 1,674
