跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair guides and support for your LG TV.
852 个问题 查看全部
HDMI Ports Suddenly Not Working
Verizon Fios Cable box signal still works fine on TV. The trouble is with the HDMI ports. We have an Apple TV, Sony BluRay, and LG DVD/surround sound unit each plugged in to the HDMI ports. None of them work, except for the Apple TV, but that signal shows with "snow" running over it. For the others, a "no signal" message appears on the screen when you select their input. I should note that each of these devices has been plugged into these ports for two-four years without trouble.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
Jessica,
LG Tvs are known for having issues with their HDMI inputs. If after performing a hard reset on the TV and replacing the HDMI cables, you still have this issue, I suggest to replace your LG TV Main Board
In order to order the right part, please get your TV model code from the back of your TV. It will help you to receive the right part.
-Mike W
这个答案有帮助吗?
得分 0
添加一条评论
A common problem w LG:s HDMI switching IC.
Follow the circuit lines from HDMI ports and heat that IC with a heatgun. First time it worked for three months, second time only one week…
Have to replace that IC or main board some day.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jessica Olson 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 6
过去的30天: 26
总计 1,144
