跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
Why are there two red lights when I turn PS3 on?
I followed the step by step process for the fix it YLOD kit. After reassembly, my PS3 had two red lights and won't turn on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I looked around the PlayStation forums for anything on two red lights after a YLOD reflow. The only solution I could find was making sure that each component was correctly connected after reassembly. Someone on the forum said that they hadn't reconnected one of the daughterboards correctly and that doing so fixed the double red light error.
I'll keep looking for other solutions, but checking all the component connections should be a good first step for solving the problem.
这个答案有帮助吗?
得分 1
添加一条评论
You haven’t put it back together properly i did the same thing you have done .
you need to connect the daughter board assembly , there is no need to try and tear it apart without any experience.So call an electrician or a technician to repair your ps3 . I have the ps3 fat , i opened it up and cleaned the motherboard but didn’t assemble it back together .
Now i fixed up everything , its working as good as new
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mvqw2828 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 32
总计 1,712
