跳转到主内容
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 个问题 查看全部
device it´s not charging after a little water test
Hi, my device it´s not charging, apart from that all it´s ok, i was just doing a water test...
in less than a 2 mins air bubbles appear in the sim port, i took it outside the water and it start to reboot with apparent sim problem then i pull off the sim, then i dry the phone with mi shirt, it restarted again and then it was working normally.
After that i put it on rice all night, but in the morning i wanted to charge it and afeter 5 seconds plugged the led turns off and appears like disconected, what can i do? thank u!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
I won't ask why you were doing a water test, no good thing can come out of that...
You may want to take the device apart and give it a clean with 99% Isopropyl alcohol and a fine tooth brush. I tend to soak in the solution then clean with a brush but you could typically have corrosion within the connectors causing the connection to fail intermittently.
Hopefully this will help, if not you might need to replace that part, although my knowledge of Sony Xperia phones is limited, not sure if this would be a solder job or not..
Hope that helps!
Will
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
rokerwhish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 154
