Broken Screen digitizer, Help!
You guys are awesome, would you know where can I get ORIGINAL OEM GENIUNE screen digitizer HTC One M 8 and what to look for, when purchasing one.
Cheers
To get an OEM part you have to take it to HTC. HTC doesn't sell their parts, so you can't get OEM unless it is used from another phone. Don't be fooled when someone says OEM online, it's typically just a reproduction or a recycled mix of aftermarket and OEM.
EDIT: Would like to add that HTC has 'Uh-Oh Protection', something you might want to look into.
这个答案有帮助吗?
Thank you for your prompt reply. Are there any differences in screen quality with these aftermarket screens, you mentioned?
这个答案有帮助吗?
there can be good ones but there can be bad ones, and by bad i mean, there can be deformed plastic, excesses UV glue, poor quality adhesive. est
Hi,
You should buy the digitizer + LCD. Not the digitizer alone. And without the frame is easier to replace.
But, there are 2 versions and perhaps you should open yours before you order.
Look at this:
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 197
