Burned resistor on GPU
My quastion is is it possible to replace resistor on a new graphics card it's called R47 thx
MSI GTX 970
Of cause you can. before replace it check the reason to burn it, check upper side MOSFET whether short circuit or not. This kind of result i have observed in over clocked GPUs. :-) keep in mind to check R22 also before powering up the graphic card. Cheers!
这个答案有帮助吗?
I am certain that by now you either have it fixed or got a new card. Anyhow, this answer is just for completion sake. For your Video card the reference designator R47 is a 56 Ohm 5% resistor in a 0402 package.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 20
总计 4,076
1条评论
Hi there,
Was reading this thread and i seem to have a burned R47 on my Sapphire RX480 8gb.
Its been running a custom bios for about 9months thus being overclocked.
The card was microstuttering for some time already and since last dustout the card wouldn't boot and it showed me a black spot and a cracked R47 near the 6pin power connector.
Any ideas on what to check here before i just replace the Inductor?
由 Robin Hak 完成的
