跳转到主内容
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 个问题 查看全部
How do I fix a dead screen?
With no other indications the screen has stopped working completely, and it just showing black. Is it possible to replace the screen myself? If so, what part do I need to order and how do I open this guy to get in there and make that replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Kode, first make sure that the issues is your LCD. Connect an external monitor and see if it displays correctly. If it is your LCD that needs to be replaced, follow this video
这个答案有帮助吗?
得分 3
6条评论:
screen was hit by toy now shows a rainbow what do i do i just ordered a new screen///
完成的
Hi quireapril,
Click on the link 'this video' above in OT03's answer. It is a video that shows how to replace the screen in an Acer C720 Chromebook.
完成的
Hey, I followed this because I had a dead screen too. It's still dark, what do I do?
完成的
@Sean Davis you are not telling us what you did. I assume your computer is a Chromebook C720
完成的
Hello. How do I fix a computer monitor that won't turn on? It was perfectly fine yesterday but then completely won't work the next day. Whenever I plug in the monitor, its power button usually lights up red but now it doesn't. Does this mean it has a power issue?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Kode 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,962
