跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
Swap top case(display) from retina 15 2012 to retina 15 late 2013?
Does anybody know if it's possible to use the top case with display from a mid 2012 macbook pro 15inch retina on a late 2013 macbook pro 15 retina?
From what i can tell the main difference is that the 2012 has a "n"airport card and the late 2013 has "ac"airport card.
Are the antennas different?
That's the only thing i see that could cause problems.
Of course,if the airport card can be swaped that could solve any antennas imcompability.
Some time ago i replaced the top case with mate screen from a 2010 macbook pro with a top case glossy from a macbook pro 2011.That time i had to swap the airport card because the 2010 had 2 antennas and the 2011 had 3.
Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
I'm having the same question. Did you change it? Is it working?
完成的
I would like to know too please.
完成的
isight cable is different. will not work
完成的
添加一条评论
3个答案
已选择的解决方案
Nope, They are different.
这个答案有帮助吗?
得分 2
添加一条评论
Plug it in and see what happens
这个答案有帮助吗?
得分 0
添加一条评论
The other answers are careless and poorly worded. Yes, you absolutely can swap the screens. It's just the iSight cable that will not be compatible, the screen itself and wifi will work perfectly fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
faocisco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 370
