跳转到主内容
Repair guides for the Motorola Moto G. A series of Android Smartphones manufactured by Motorola Mobility since 2013.
974 个问题 查看全部
My phone doesn't show me a specific wifi network
Hey guys, My phone can't seems to find a specific wi-fi, I pressed scan and it doesn't come up for some reason, it used to. I've tried everything, turn the phone of, take the battery out, blow of dust, play around with the settings, but it doesn't appeared in the wifi list.
The phone is finding my neighbors & office wi-fi and can connect to the them perfectly, so I'm really confused.
The specific wifi network which I want to connect in my phone, is working perfectly with other devices, also my friend's phone can connect to it.
So the bottom line is, only my phone is not able to see this specific wifi network in the list. other device can find it and can connect to it.
Does anyone know whats wrong, has this ever happened to anyone else?
HELPPPPPPPPPP
Phone: MOTO G (first generation)
Android version: lolypop
PS: THIS IS MY FIRST EVERY POST ON THESE FORUMS, SO IM NOT SURE WHAT IM DOING AND WHAT INFORMATION YOU GUYS MIGHT NEED. THANKS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
Dude , I am getting the same problem . I you have got the solution please forward it to me at jindaludit23@gmail.com .
thanks.
这个答案有帮助吗?
得分 0
添加一条评论
Does your friend have the same type phone. may be the wifi network have different band? You can install
https://f-droid.org/repository/browse/?f...
https://play.google.com/store/apps/detai...
Do not worry it is open-source software (no spyware). In this app, you can scan networks and see what networks, bands, channels, strength are available. Or install it in your friends phone find details.
这个答案有帮助吗?
得分 0
添加一条评论
This might help but at the same time it might not but,
Try going to your wifi and if the wifi you are searching for is not there, there might be a tab that says search for wifi, type in the wifi name you are looking for and it should pop up
~Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shiv 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 18
总计 3,606
