跳转到主内容
Repair and disassembly guides and support for dish washing appliances.
702 个问题 查看全部
dishwasher motor connection 110v
hi. all...
i have a dishwasher motor and i want to use it to make a cheese grinder, so my question is how to connect with 110v direct to work... the other piece with the white plastic i don't need.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
7条评论
it come out of G&E DISHWASHER..CAN I REMOVE THE SOLENOID OR NOT..
完成的
Give us more info on the motor itself. Yes you should remove the solenoid etc. Since it appears to be a pump there should also be an impeller at the end of the shaft etc. Post more images of your pump. right now it looks like the motor connects to the pump housing via the screws on the top corners. So, the solenoid and the motor are connected to the pump housing. You may have to remove it, but it will depend on the design of your cheese grinder.
完成的
I going to remove the solenoid and the white plastic and the side pice, so if I connect the power on the top connecter you think it should work,
完成的
That is the way I would proceed.
完成的
OK, i try tomorrow to connect the power??
完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
vitodeluca, it might help a bit more if you tell us what model motor this is and/or what dishwasher it comes out of. Right now it looks like the Recirculation Pump motor. The part on the left looks like the solenoid to shut the flow of. The AC (power)connections are the once above the thumb in the picture.
update
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
vitodeluca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 262
