跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4099 个问题 查看全部
Left side of screen not working - Cannot press 'Q' '1'
After replacing the screen on my iPhone 5s (16GB white and silver) the left side has some daed spots, I cannot press 'Q' or '1' in portrait, the bottom left icon also doesn't work.
What should I trouble shoot? There are no strange lines or screen bleeds.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
评论:
Thanks guys, indeed the iPhone was bent, I did bend it back and didn't think it fit with pressure. I'll check with the screen not inserted, to see if it's caused by the frame.
完成的
添加一条评论
2个回答
最有帮助的答案
I would open it back up again and reconnect the digitizer cable, maybe there is some dirt in the connector? Give it a wipe with isopropyl if you have any. If that doesn't work, it might suggest that the new screen is faulty. Also check the phone is not bent, did you have a hard time getting the screen to clip back into the frame? I once did a screen repair on a 5S, that had similar problems you describe, on close inspection, I noticed the iPhone was bent, and so the new screen was obviously bending to the shape of the frame.
这个答案有帮助吗?
得分 1
添加一条评论
Make sure you screen is not being pressured by anything. Try loosing the LCD Shield plate scews and check the phones reaction. As Michael stated, if the iPhone is bent, the new screen will follow the shape of the frame and it would damage the new screen. If there's no line on your screen and everything is shining bright, the cables are probably not the cause of your issue.
Regards,
Bruno
这个答案有帮助吗?
得分 1
评论:
Bought the gTool and got the corners perfect. Screen fitting good.
That did not solve it, when I remove the metal backplate it seems the screen responds better, the plate doesn't look bent. Whattodo whattodo
完成的
Ey Giovanni. Three years later I’m facing the same problem in my 5s. What did you do to solve it? Thanks!
完成的
添加一条评论
添加你的答案
Giovanni Joubert 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 21
过去的30天: 135
总计 12,898
