Can I replace an iBook G4 12" with a G3 800mhz?
The logic board on my 12" iBook G4 has died and I have come across an iBook G3 800mhz logic board.
Can I put this in assuming I'm clever enough to follow ifixit's instructions?
The aluminum frame the motherboard mounts to is different in G4s, so hopefully the board you came across has a frame attached? Also, G3s have a tray-loaded rather than a slot-loaded optical drive, so that will be a problem due to various components being designed differently for that.
And actually, the topcase plugs are generally different, and the video plug on the motherboard is different between G3s/G4s as well, so really now that I think about it the answer to your question is looking like "no", aside from being able to salvage a few various parts (battery, the screen unit itself inside the frame, etc.)
这个答案有帮助吗?
Thankyou for your answer.
Unfortunately there is no frame with the board. In fact there's nothing except the vanilla logic board, also quite unfortunately.
Is there any way I can fit/adapt this board into the G4? I don't mind light soldering, but count me out if there's dremel work.
Quite happy to buy a new machine, but there is some sort of attachment to the old iBook which has served me so well for nearly 6 years.
这个答案有帮助吗?
Personally, if it's got to the point where you are downgrading it to keep it running I would give up on it.
In my view it's just not realistic. Many connectors are different, you'd need to get a hold of various plugs and cables specific to the G3 board, and even if you were a master solderer and did pull it off you'd have a frankenstein machine that was not quite a fully functional machine, if only due to the optical drive mismatch issue. I say pay $20 on eBay for a G3 parts machine to put it into, or get a working G4 board out of a parts machine, and keep going with your existing laptop.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,461
