跳转到主内容
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 个问题 查看全部
What will I do when my battery is not charging
When im charging my tab it charges but when I turn on my tab it continues to turn off and even I charge them for many hours like 9 hrs or 10 it not charges and it still 26% and also when i charge my tab for many hours it still lowbat and never get full charge or 100% please help me thank you :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I hate when this happens, like right now its completely dead and i will have it on the charger all day and night. And it will turn with a screen with a battery and then another screen with the same battery to show how much it is charging.And then it'll turn off.
完成的
添加一条评论
1个答案
最有帮助的答案
Go to setting -> about -> status -> check the power source identification (when you plug the charger is must show as "AC" anyhow it's showing USB when you plug the charger you can do below steps to troubleshoot the fault)
1) Change the charger and check.
2) Repair/ Replace the Micro USB interface and check
3) if the same fault remain you need to check power management IC
if power source properly identified by tab you can check the Battery capacity using battery analyzer. and check the power consumption using variable power supply
这个答案有帮助吗?
得分 1
1条评论:
My Tab will say a full charge but when I turn it on it will go down in a couple of minutes. It will not stay charged.
完成的
添加一条评论
添加你的答案
yukiro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 881
