跳转到主内容
The D-Link DNS-323 is a two-bay network storage enclosure that is designed as a comprehensive solution for network storage.
4 个问题 查看全部
Need Help with DNS-323
Hi, I have swapped out the two 2TB HDD and it only seems the left side will connect (map). The front blue indicator shows both drives but only one connects, the second one does from time to time, it has always been like this from day one, any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Check how your raid access is set up.
It may be the config isn’t correct
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tread72 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 311
