Pls HELP! Anybody know what this code is? 4SNS/1/40000000: lbor-9.426
I run extended AHT on my MBP 2011 13" and this came up on the results.
Please I need to know what wrong with my MBP.
It runs very slow and stuttering.
Thank you in advance.
First I'd like to know your exact machine, please give us the last four figures of your serial number. Next, can you give us a history of any problems or repairs that you've done. What operating system are you running? Do you have anti-virus installed? Have you installed any crap like MacKeeper? It's an unusual sensor problem error but I doubt that that is your actual problem. Are you getting a lot of beach ball on start up? I'd like you to do two things; first let's look at Old Turkeys battery idea by downloading and running Coconut Battery and report your results: http://www.coconut-flavour.com/coconutba...
Second, put an operating system on a flash drive or other external drive. Disconnect your hard drive cable from the logic board and boot from the external drive. Does the problem persist?
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 51
4条评论
denzdaniel, that looks like a Battery Current Sense error. Have you tried a SMC reset?
由 oldturkey03 完成的
yes i did, 5 times! I even did the NVRAM reset. Still slow macbook pro.
How positive you are that the battery sensor is the problem?
thanks.
由 denzdaniel 完成的
Hi Mayer,
DV13 are the last serial figures.
Running Mavericks 10.9
No anti-virus installed, no MacKeeper.
The problem is caused by the coffee spill.
I did the rice thing for a week, cleaned the Logic Board with isopropyl.
I cleaned all surface carefully and all port. I used the blow dryer to dry it.
It works, but it is just super duper slow. Yeah i get beachballs, but the system is just slow. Everything is slow.
Boot up takes forever, after login everything just is just very slow.
So i did the AHT then I got those numbers/codes.
I will try to boot to an external drive thanks. I will update you.
由 denzdaniel 完成的
Apple MacBook Pro "Core i5" 2.4 13" Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555*
由 mayer 完成的
