跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
989 个问题 查看全部
screen not coming up when turned on
Hi There, I have an IPAD2 with WIFI and it was working perfectly till about a few days ago, where the screen is black with a very ligh huge of blue in the back (I can see it if the lights are dimmed. I can hear the background and can tell when it is on or off but thats all I am getting from this. Please advice if there is a solution for this. Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
最有帮助的答案
Try giving the ipad a good smack on the back side of it. The way that lcd connection is hooked up it can come loose and hitting it can reseat that connector. Let me know if that helps.
这个答案有帮助吗?
得分 1
评论:
If the smacks don't work it will likely need to be opened up and have the lcd cable reseated.
完成的
添加一条评论
You most likely need to replace the LCD. it's not hard to do if you have experience heating and prying screens, but you do need to be careful not to break it or damage any cables during the removal.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
neslire 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 114
