跳转到主内容
This laptop from HP was released in November 2011. It has a 17.3" display and and comes in either silver or nero black.
Why isn't my computer turning on?
I'm pushing the power button, but nothing is happening.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Your battery might be dead. Try plugging your charger in to your computer and then turning it on again. If that works, you might just need to charge your battery. If you have your charger in and the computer turns on but the battery isn't actually storing any power, you will need to replace your battery. There is a guide for replacing a battery at the following link:
HP Envy 17-3070nr Battery Replacement
If using the charger doesn't fix the problem and you know the charger isn't broken, then try referring to the troubleshooting page for this laptop at the following link:
HP Envy 17-3070nr Troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
Sometimes this computer's power lock can be enabled due to some fault, to unlock it, simply press and hold both the power button and beats button at the same time.
这个答案有帮助吗?
得分 0
5条评论:
what is the "beats Button"
完成的
3051cl hp computer, boots sometimes, sometimes it won't boot. Tried holding button 30 seconds to no avail. Tried holding windows button & B & power button at same time to no avail. not sure what the "Beats Button is?
完成的
Tried all that to no avail, had it in computer shop 3 times to no avail. Sometimes it boots, sometimes it doesn't. Repair man gave its a good cleaning and it worked. Brought it home, worked for a day, now it won't boot again?
完成的
When it boots, it shows a full charge.
完成的
When holding start button down for 30 seconds, LED light next to charging port blinks 3 times, pauses, blinks 3 time, pauses, etc etc?
完成的
添加一条评论
添加你的答案
Jon Fuson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 568
