跳转到主内容
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
22 个问题 查看全部
no electric to horn, lights, and starter
tried to start scooter after a long winter, but nothing. tried charging the battery, and still nothing. replaced the battery and still nothing. no lights, no horn and no attempt to start even with a new battery,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
sandycav, check the wiring on the battery connectors, make sure they are nice and clean. Your scooter has a main fuse in the power line. Check that one for continuity and make sure that you have power going to the fuse. If all that is okay, use the attached diagram to check for power. You will of course need a multimeter for that.
这个答案有帮助吗?
得分 2
1条评论:
Thanks! I've visually checked the fuse yesterday and it looked ok. I'll get a multimeter and try to check from the battery out.
完成的
添加一条评论
添加你的答案
sandycav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 30
总计 6,067
