跳转到主内容
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
58 个问题 查看全部
Why does the engine warning light remain on
The engine warning light remains on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
it's the egr valve most likely. common ford problem
完成的
添加一条评论
3个答案
已选择的解决方案
The engine light is telling you theres something wrong with your car and that you need to give it some attention . You can start by getting a OBDll reader and getting the code to tell you just what you need to fix. Once you have the code and have fixed the problem you can delete the code and the light will be out
这个答案有帮助吗?
得分 1
添加一条评论
You do not give us a lot to go on. I suggest that you get the OBD scanned at places like Autozone or others and see what code it returns. there are hundreds of reasons why the light could be on.
这个答案有帮助吗?
得分 0
添加一条评论
Replace the engine if it's bad
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dbryantnc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 504
