跳转到主内容
The Xelio P1001A-BK is a low cost, full featured tablet computer based on the Android Operating System. It features a 10.1" full color capacitive touch screen, micro SD card reader, and full stereo sound.
1 个问题 查看全部
问题已关闭
Why won't my tablet charge?
I plug my charger into the power socket but the battery icon on the screen does not show the tablet is charging. I checked the power plug and it seems to be firmly in place. What could be wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The most common power problem is either a defective power supply or the power cord has a break in it. If you have a volt-ohm meter you can check to see if you have voltage at the power plug. If you do not you can try to check if the power supply is putting out power by baring the power cord wires near the base of the power supply and testing them for voltage. If you have voltage then you know you have a break in the power cord wires and you can repair or replace the wire. If you do not have power coming out of the supply then the supply is defective and you must replace it.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 177
