跳转到主内容
Released on June 18, 2013, this Android smartphone features dual SIM card support, a 4.7" 720p display, a quad-core processor, and 2 GB of RAM.
22 个问题 查看全部
Reboot loop! Factory reset didn't work!
Suddenly, after 1 year and 6 months since its purchase, my phone stopped working properly. I was pressing the power off button to unlock the screen, but it didn't work...after a while it opened by its own and I was able to use it properly but I couldn't lock it again!
After that, the phone started rebooting without stop!
I managed to reset it by the settings but it didn't get any better.
Battery is charging properly and the percentage of it is the right one.
Is there anything I can do?
Can you make any guess what's going wrong? Is it fixable or I should start mourning on my Huawei?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 47
17条评论
Accidentally erase your valuable data by ROM flashing, factory resetting, deleting, rooting or others? Of course you can always turn to experts. But it may be very costly. Being safe and trouble-free, Android Data Recovery is a good tool to recover data from Android operating systems—Android 4.0, Android 4.4, Android 5.0, etc. Sim Card data, external storage data and internal storage data are all recoverable.
Android Data Recovery is a user-friendly program for data recovery. Unlike other recovery tools, it covers a wider range of data types, which includes photos, contacts, messages and so forth, and a wider range of android devices.
So, if you lost your data from Huawei after reboot loop or factory reset, you can try using this tool to restore lost data from Huawei phone
完成的
I have a frustrating problem.
So I downloaded a kitkat launcher on my huawei ascend P6 and after the download my phone went off and ever since then I am in a bootloop. I tried the +volume and power button but it just swtches off and then back into the bootloop. IS THIS THE END?
完成的
I had the same problem..after 1 year and 6 month as well!!&&^&!i am not able to fix it!
完成的
I've had same problem in Huawei Ascend Y540. It was the microSD card faulty (7 years old). With no microSD no reboots.
完成的
i reset my huawei y360-u61 butt their is some problem during reset . on last step privacy declare its not working
完成的
显示更多的12条评论
添加一条评论
11个答案
已选择的解决方案
1) download the firmware by below link
http://consumer.huawei.com/en/mobile-pho...
2) Copy it to SD card and rename the folder to DLOAD
3) Boot to recovery mode : Vol down + power
4) Update the firmware
Note : data will be lost
这个答案有帮助吗?
得分 22
10条评论:
vol down + power not working still restarting
完成的
Fasil, Check the keys
完成的
vol up + vol down + power....
完成的
I did it, 5 times..!! and it's still in bootloop .
to be fair it started and reached email verification step then it's in a bootloop all over again.
完成的
i cant do it, cause my internet doesnt switches on. what do I do now :/ ?
完成的
显示更多的5条评论
添加一条评论
The link for the firmware in Buddhika Mahesh post appears to be working now. If you still can't get it to download try the link below, it is a direct link to the zip file from Huawei.
Android 4.2,Emtion UI,V100R001C00B111,General Version (Newest Version)
This is the previous release if you would rather try it instead.
Android 4.2,Emtion UI,V100R001C00B107,General Version (Previous Release)
Download one of these and then complete steps 2-4 from Buddika's post.
这个答案有帮助吗?
得分 7
2条评论:
Do you have a link for Honor 4C, please? I couldn't find it anywhere online.
完成的
both links are now dead as it says page unavailable
完成的
添加一条评论
I followed all the steps to update my Huawei G610-U20 from sd card, but my phone doesn't see update.app file when I select the dload folder. Can anybody help me with this?
这个答案有帮助吗?
得分 3
10条评论:
The solutions didn't work for me. I put update.app in SD-ram, and restart it, but the file wasn't in Dload folder.
The problem started when I moved some Apps from internal to SDram, and tried to clear Apps data to free some memory. My Huwaei G610-u20 stuck there, calculating allocated memory for each App, even after few weeks that was there "Calculatin memory". Then I received too many updating messages for all Apps.
I used Husuite tools, Flash-Tool, but they didn't work. Now, I am in this loop: I uninstall all Apps, then after few minutes, it restarted and I see all Apps. I have used this phone for about 2 years, and there is no supprt. Never buy a Huwaei again
完成的
we have the same phone and with the same problems bro.. Huawei G610-U20
完成的
Having the same problem with Huawei G8
完成的
i have the same problem with the exact same phone
完成的
same problem with g610u20!!!! can it be a virus !!?or its a hardware problem...
完成的
显示更多的5条评论
添加一条评论
huawei p6-u06 cmiit id :2013pc0680
这个答案有帮助吗?
得分 1
2条评论:
I have huawei y3 it didnt workafter I received a call..now it it shows select language and region..and need google account password but I forgot them
完成的
I’m facing the same problem in Huawei Y7. Very frustrating.
完成的
添加一条评论
I've trying to reboot my huawei Y600 even using hard reset is not working.
这个答案有帮助吗?
得分 1
添加一条评论
huawei phones are $@$*!& i would not advice anybody to be using dem phones. They need to revamp their development and hardware.
这个答案有帮助吗?
得分 1
1条评论:
your not helping
完成的
添加一条评论
Same problem in Huawei Ascend Y540 Phone.
这个答案有帮助吗?
得分 1
添加一条评论
I have exactly the same problem. I tried to put my phone in the fridge over night (dont ask me why) and guess what. The phone started up just fine! But Im only able to launch one single app. If I try to start more than one app it crashes. And if i reboot the phone it will go into bootloop again. It start up again if i leave it in the fridge for more than 5 hours. Weird.
这个答案有帮助吗?
得分 1
添加一条评论
My phone has stopped working ...i was watching some movie then It turned itself off... After like one minute I brought these words....
Emergency data
The user partition can not be used again , please select the opertion as follows..
Back up
Factory data reset
Reboot the phone
These words are the one that remain on the screen.... Applications are not seen...
I need yr agent help
It's hauwei Y330
+256703810196
+256774836235
MY CONTACTS
这个答案有帮助吗?
得分 1
1条评论:
Same phone with same problem I don't know what to do.I was using this phone for business and now I lose my clients.
完成的
添加一条评论
i tried dc phoenix failed ...dont try it lost your money.
这个答案有帮助吗?
得分 1
添加一条评论
https://okadtech.com/huawei-boot-loop-is... just and go and solve your issue and thanks me later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
w12n 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 124
总计 256,109
