跳转到主内容
加入维修社区 - 创建账户
型号A1288,闪存容量:8、16及32GB
Screen cracked, and now black spots appearing
The device has a thin crack, no problems with how it works. After it was left in hot car, a black dot appeared on screen, and now it is growing in size, obscuring an app icon.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 51
1条评论
thanks for your help...sounds like it may be more prudent to get a new one!
由完成的
添加一条评论
5个答案
已选择的解决方案
sounds like the lcd has a crack, the term "screen" is problematic, some say screen to the front panel assembly (aka the touch screen) and others call the lcd a screen.
but since the "touch screen" can't get a real black dot - it must be a crack in the lcd.
you have to replace LCD and if there is also a crack on the front panel - you must replace it too.
这个答案有帮助吗?
得分 8
2条评论:
由完成的
i left mine in my pocket and pulled it out and it became like this
由完成的
添加一条评论
its either oil from your hands getting onto the lcd screen or pressure points on it, I'm not sure which most people seem to think it's pressure points base on my solutions that have worked I think it's oil. First thing to do is cover it with something to stop it from growing(packaging tape worked at least as well as a screen protector on my droid x). After that, it will very slowly decrease in size by itself. If you get it cold it will speed the process along.
这个答案有帮助吗?
得分 3
添加一条评论
I've crack my phone like 3 times and now there a line of black things just growing into it, how do I fix that, also my phone is a j3 Luna samsung
这个答案有帮助吗?
得分 3
添加一条评论
I have the same thing on my IPhone5c it have black spots on it and it want let me do nothing i tried to do everything and I went to put some water on it still did work so maybe try clicking home button 3 times or Try clicking the Home button 3 times (really fast). If that doesn't fix it, go to Settings/General/Accessibility/Triple-click Home, and select the "White on Black" option. Then, triple-click the Home button.
这个答案有帮助吗?
得分 0
添加一条评论
My phone has a crack and now a big black spot is on my phone how do I get rid of it or do I have to take it in for someone to repair it my phone is a LG k7
这个答案有帮助吗?
得分 0
2条评论:
Same deal here, I dropped my phone and running through the cracks it has this black liquid looking stuff, slowly growing if theres pressure in the area. What is happening here?
由完成的
It is most likely that your LCD screen has been damaged. As you were running, The phone could have hit the hard surface and revealed the black ink spot below your screen. You can get the LCD screen replaced or get the whole thing replaced.
由完成的
添加一条评论
添加你的答案
lorettalevy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 47
总计 117,535
