跳转到主内容
Model A1051 / 4 or 6 GB hard drive
87 个问题 查看全部
Why doesn't my click wheel work after I changed the battery?
The new battery charged up fine and the display is fine, but nothing happens when I push the click wheel. When I reassembled after putting in the new battery, it did not seem as if the orange click wheel ribbon stuck back onto the logic board; I hoped the metal bracket would hold it down in the right way, but apparently not. Is this fixable? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Sounds like you did not properly seat the connector back into the board. I would take it apart once again and make sure you properly seat the click wheel connector in it.s socket before attempting to close. just hope you didn't damage the connector on either end when you closed it without properly seating it. Use this guide here
这个答案有帮助吗?
得分 2
1条评论:
+ Ralph
完成的
添加一条评论
Like Majesty said, you most likely did not seat the connector properly back in place. If it is seated properly, however, then you may have damaged the connector or ribbon cable when working on the unit.
这个答案有帮助吗?
得分 0
添加一条评论
I would recommend looking for damage in the cable or a lose connection like others said, however, sometimes when reinstalling the board, if it scrapes to much against the metal shell, it can cause a chip to break or fall out. There’s one chip that, if broken, will make the click wheel cease to work however the rest of the ipod would work fine. and lastly, I’m surprised no one so far has recommended taking off the top bezel and making sure the lock switch is in the right position, as that could be the problem and would be a very simple fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ekeeling 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 3,841
