跳转到主内容
My power button is not working lenovo a7000
I have charged my phone overnight.In the morning i came to see that my power button is not working.Help me out
lenovo a7000
回答此问题 我也有这个问题
这是一个好问题吗?
得分 15
3条评论
lenovo a7000 switch solution
完成的
my phone was not getting charged more than 15% and now it cant be switched on? plz help
完成的
What to do if lenevo 480060a2 on off button is not working . And if mobile phone get switch off
完成的
添加一条评论
7个答案
最有帮助的答案
这个答案有帮助吗?
得分 3
添加一条评论
I faccing same problem
help to out me from this problem
这个答案有帮助吗?
得分 1
2条评论:
Facing same problem.
完成的
Turn on tap to wake from menu. that's how i bypassed the power button bullcrap.
完成的
添加一条评论
1) Connect your phone to a computer using USB
2) Hold upper volume key for 5 seconds as soon as your phone is plugged in to a computer using USB cable.
3) A menu will appear. Use upper volume key and go to the 3rd option which is " boot normal"
4) Press lower volume key for selecting that option.
Your phone will be switched on automatically.
这个答案有帮助吗?
得分 1
添加一条评论
Restart it just by adding the restart button in the notification panel when you slide down you'll see a 4 dot at the right side.
这个答案有帮助吗?
得分 0
添加一条评论
I have lenovo a7000 I charge phone at night next day phone is not switch on what should I do
这个答案有帮助吗?
得分 0
添加一条评论
Change Sleep option to ‘Never’ under settings, display option. Although this isnt a solution, may temporarily address the problem, at the cost of draining batter
这个答案有帮助吗?
得分 0
添加一条评论
My power button was broken
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
arjnkar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 14,315
