跳转到主内容
修复你的物品
维修的权力
商店
This is a Panasonic DMC-ZS8 digital camera. On this page you will find how-to-guides on how to fix and replace componets such as the front panel, the mounting bracket, the battery door, the screen panel, and the front lens.
10 个问题 查看全部
What should I do if I stripped the mounting bracket?
Hello,
I accidently stripped the holes to my mounting bracket on my camera. I really hope there is a simple solution to this seeming how I just got this camera as a gift on Christmas!
Any help at all would be great!
Thank You,
Elijah Painter
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
2个回答
已选择的解决方案
Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement
这个答案有帮助吗?
得分 0
添加一条评论
You will have to remove it with a set of tools. A magnet can help once you pull the screw out with a different head screwdriver. Given the type of screw it was to begin with, a different style and size can be used to get a grip on the hole and loosen it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Elijah Painter 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 72
