跳转到主内容
Released May 2012, identified by model number J2011-03-US.
45 个问题 查看全部
My charge port came loose, how can I fix this?
I was forewarned about this problem before I bought my Jambox, but I didn't think it would ever happen to me. I was simply trying to charge my Jambox through the charge port, but I might have plugged it in too aggressively because the charge port came loose! It honestly just fell out, and I have absolutely no idea how to fix it.
I'm pretty upset because I just got my Jambox this past year for Christmas and it's already broken! Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
添加一条评论
4个答案
最有帮助的答案
Don’t worry, this is a common problem! Although it does take a little bit of effort to get the charge port back in place, it can be accomplished with the proper equipment and the helpful information offered on the troubleshooting guide offered for the Big Jambox.
Basically, the part will require some soldering and that should pretty much fix your problem. I hope you find the solution!
这个答案有帮助吗?
得分 2
3条评论:
Does anyone have the size / type of the DC barrel connector? My Jambox took a tumble when I lent it out and apparently the DC connector hit first, it popped off the board and the connector itself is in about 6 or 7 pieces...
TIA
完成的
http://www.digikey.com/product-search/en...
This is a direct replacement.
完成的
One more thing - It seems I lost C14 in the fall as well. Anyone know a good replacement Part# for that cap, or can I just get away with bridging it?
完成的
添加一条评论
This is a direct replacement barrel connector. You will obviously have to solider it to the board. Just copy and paste in your search box. The part cost less than a couple bucks. Hope this helped
这个答案有帮助吗?
得分 0
1条评论:
Awesome! This is great thanks so much for the link!
完成的
添加一条评论
can you still charge with usb even when the ac charger port is broken? does the circuit board need the power jack port soldered in to function?
(I know usb charges slowly and not fully, shortening battery life before the ac port was broken)
这个答案有帮助吗?
得分 0
添加一条评论
My charging port got detached from the board,a repairer repaired it but could work so I want to get a new board, will I get the bored to buy .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriella Graham 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 50
总计 18,067
