跳转到主内容
A Makita angle grinder released in June of 2010. Model number GA4030K.
4 个问题 查看全部
Angle grinder won't turn on after I dropped it.
I was using my angle grinder to work on a small project the other evening when I was startled and dropped the grinder off of my work bench. Now, when I try to use it, the grinder won’t turn on at all. I tried plugging it into several different outlets throughout my house and that doesn't seem to be the problem so I think it must be the grinder itself. Is there any way to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Your angle grinder may be making noise because it is overworked. Machines, like humans, don’t function well after heavy loads for prolonged periods of time. It is recommended that you allow the device to spin freely after a moderate amount of difficult work before resuming your project.
The angle grinder is fixable - visit the ‘overworking’ link on the troubleshooting page found here:
Makita GA4030K Troubleshooting
这个答案有帮助吗?
得分 1
1条评论:
The answer provided does not match the question.
完成的
添加一条评论
添加你的答案
Nyssa Backes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 6,282
