跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
问题已关闭
How to remove iPhone display assembly
After replacing a friend's iPhone screen, I found that I needed to reseat some display cables, but I couldn't get the new display back open. My suction cup would come off before the display would budge. Does anyone know another way?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
At the Headphone Jack corner, just above the Headphone Jack port, the front screen frame has a very thin area which can accommodate a thin pry tool. The tip of a razor blade could be used. Carefully insert the tip down between the iPhone frame and the screen frame about half a mm, and pry up the screen. Be careful not to damage either frame. Look at an old screen to see this area.
这个答案有帮助吗?
得分 1
1条评论:
Thanks! I tried that, and it worked, but the display only moved a tiny bit... Would I put a pick in to hold the display?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 74
