跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
764 个问题 查看全部
Aluminium back panel has become competely dettached from rubber panel.
After upgrading my HDD I was screwing in the back panel and I noticed the rubber coating had come off in some places.
While trying to slip it back on over the aluminium, the circular plastic pegs that fit in the holes in the aluminium panel came out of place and the aluminium and rubber are completely dettached.
IF ANYONE CAN HELP PLEASE DO.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个回答
已选择的解决方案
MacBook Bottom Case Replacement Program
Apple has determined that under certain circumstances the rubber surface on some MacBooks may separate from the bottom case of the system. MacBooks shipped between October 2009 and April 2011 may experience this issue.
Apple will replace the bottom case of any affected MacBook, free of charge, that exhibits the issue.
Bottom Case Replacement Process
You may choose from three options to get a replacement bottom case for your MacBook. In all cases, your MacBook serial number will be checked to verify that it is eligible for this program.
Assisted service
Visit an Apple Retail Store - Set up an appointment with a Genius: http://www.apple.com/retail/storelist/
Visit an Apple Authorized Service Provider - Find one here: http://support.apple.com/kb/HT1434
Self service
Order a replacement bottom case kit online.
You will receive a kit that includes a new bottom case, screws, a Phillips head screwdriver, and instructions for how to remove the current bottom case and install the new one.
If you feel comfortable with the self-service option, you can place your order via the web: https://supportform.apple.com/201105/
Note: If your MacBook does not exhibit any signs of this issue, no action is required on your part at this time.
Additional Information
If you believe you have paid for a repair or replacement due to this issue, contact Apple regarding a refund.
This worldwide Apple program does not extend the standard warranty coverage of the affected MacBook.
This program covers affected MacBooks for two years from original purchase date. Apple will continue to evaluate the service data and will provide further extensions to this program as needed.
http://www.apple.com/support/macbook-bot...
这个答案有帮助吗?
得分 5
评论:
Theres no fee at all from Apple...and usually is shipped overnight! I've gotten 4 so far.....
完成的
添加一条评论
Apple has acknowledged that this is a problem with this particular model. They have a replacement program where you can order a new cover (for a small fee). It includes a replacement cover along with the necessary screws. This can happen if you're using it on your lap. The underside of the computer can get quite hot, and this can cause the adhesive underneath to break down, causing the rubber to come off. If your computer is under warranty, it can be replaced for free at any Apple Store. Just be sure to show your sales receipt as verification.
这个答案有帮助吗?
得分 2
评论:
+ close summary
完成的
添加一条评论
Try a little super glue
- use it sparingly it will "wick" into place. Tack it in place then finish the length... keep some finger nail polish remover handy for excess. Use paper towels not cotton lint (q-tip or ball).
If this answer is acceptable please return and mark it.
Good Luck,
N.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
superash 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 3,159
