跳转到主内容
Released May 2014, also identified as Nokia RM-1030/RM-1042 Android Smartphone.
20 个问题 查看全部
Internet icon does not work
when I downloaded firefox browser the internet icon did not work. Kindly would you assist to rectify this problem. When I click on the internet icon it gives this message "Internet has stopped" Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 28
1条评论
my phones ok but the I cannot turn off the mobile data
when turn off the data and lockscreen it well on automatically so pls help me in this situation
完成的
添加一条评论
8个答案
最有帮助的答案
For Nokia XL User:
go to Setting , Phone , Apps , After Select Manage Apps , Right side of Corner Select All folder , there Icon Showing internet Option, Select and do the following below
Force Stop
Turn Off
Clear Data
Clear Cache
Clear Defaults after turn on and open Internet browser again
这个答案有帮助吗?
得分 16
9条评论:
It worked perfectly. Thank you so much.
完成的
Thanks a lot. It's working perfectly. Saju Joseph.
完成的
Thanks a lot , u helped me to fix it .....thanks ...
完成的
My phone's internet is now running well. Big help, thanks a lot!
完成的
You helped me a lot!!!!! thank you !!!!! love you!!!
完成的
显示更多的4条评论
添加一条评论
try this
first disconnect your WiFi or internet connection
go to the browser setting go to clear private data icon
then clear all data
shutdown and restart
这个答案有帮助吗?
得分 2
4条评论:
did not help
完成的
it's not helpful.
完成的
but all my data will be cleaned,is there another solution??
完成的
thank you very much. It was of great help
完成的
添加一条评论
yes i also have this problem right now,but i couln't solve it til now,pls help
这个答案有帮助吗?
得分 0
添加一条评论
Nokia browser has stopped
这个答案有帮助吗?
得分 0
1条评论:
My browser dosent download any things?
完成的
添加一条评论
super guruuuuuuuuuuu
这个答案有帮助吗?
得分 0
添加一条评论
hi.
my nokia xl phone some file are auto install, & the file name of auto install com.google backup is not stop. i am many time reomve this file but this file auto instal in my phone please send the solution on this problem
Ajay
这个答案有帮助吗?
得分 0
1条评论:
My Nokia RM 980 I was Selected SIM1 For 3 G Use But Now My Sim1 Slot is not working so i need to use it for SIM2 so if i going to choose for SIM 2 it is not working plz help me
完成的
添加一条评论
upgrade firmware its over
这个答案有帮助吗?
得分 0
添加一条评论
A web browser acts as an interface between a user and internet. It used for several purposes like accessing websites, searching and retrieving data, etc. We are providing Online browser support in order to serve quick solutions when a fault is occurred while using them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ahmed Mustafa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 13,159
