跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
591 个问题 查看全部
Logic Board of i5 & i7 - difference for replace?
Hallo,
My macbook pro i7 fell to the ground.
Lower case, Upper case and cover of the display is Demage But everything worked perfectly.
I would buy another macbook pro 15" and replace all the internal components of the fallen.
If I buy an i5 model or a 2009 model, can I replace the logic board and display high resolution?
If this is not possible, you can tell the parts relating to the whole of the MacBook casing (including top) ?
Thanks so much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
The i5 components are compatible and interchangeable with the i7 machine. However, due to a complete internal design change, the 2009 model is not compatible or interchangeable with the i5 or i7 models.
Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Roby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 3,370
