跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1232 个问题 查看全部
问题已关闭
iPhone 5c: Replaced lightning port and battery but still won't charge?!
My daughter did a number on her iPhone 5c and I replaced the lightning port assembly, the loudspeaker assembly and the battery. Now the battery won't charge. When I plug the cable in I get the tone and the charging icon but the battery level never goes up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you try to see if it makes a difference if you re-install the old battery?
完成的
添加一条评论
2个答案
This might be a dumb question, but have you tried a different cable?
这个答案有帮助吗?
得分 0
1条评论:
I tried 3 different cables, two different AC adapters and plugging it into the wall and the computer (3 different USB ports). No dice.
完成的
添加一条评论
What exactly happened to the iPhone while in your daughter's possession? You may possibly be experiencing a failure in the logic board "power management ic", assuming your replacement battery-cable-connector wasn't somehow defective. It is generally an uncommon occurrence (and an expensive fix, unfortunately), but some experts think cheap, "fake" Apple chargers/cables are to blame for the bulk of these failures. Please check out this article to see if it sounds like your problem: https://www.mendmyi.com/blog/2014/06/has...
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 236
